I have 2 3x140 radiators on a build I'm working on. I'm using an Aquacomputer Aquastream XT pump that has a fan controller built in, but it's only rated for 3 fans, so I'm guessing around 10W at the most? I'm using fans that total around 50W at full tilt, which would probably do bad things to the analog fan controller built into the pump. And yes, it is analog not PWM.
Is there a simple circuit I can build that would match the output voltage of my water pump's fan speed controller? Or even better, one I can buy already assembled?
Thanks in advance!
Thanks in advance!
