- Jan 9, 2006
Open bench, no case. Also how do I change priority on the smp to low?
The default priority for FAH clients (all fah clients), is "idle". "Idle" is called "low" in task manager.
In the systray smp client, you can use the "configure" options page. Click on the FAH icon and select "configure", and then select "advanced".
In the console client, you can either start the client with the -configonly startup flag, or you can delete your client.cfg file, so lots of ways, but you have to get to the setup questions.
Answer your questions, and then when it asks "Change Advanced Options?" answer yes.
The core priority [idle or low] will be the first or second question in Advanced Options.
Remember that FAH's "idle" == Task Manager's "low", and FAH's "low" == Task Manager's "Below Normal".
Now! Aren't you glad you asked!!
I could more helpful explaining these things, if you would just
**GET YOUR HARDASS OUTTA MY REAR-VIEW MIRROR, AND OFF MY THREAT LIST**
