Help - got WU but not folding
Cjwinnit
B&
UK
Hi. Got the following message. Built the computer a few months ago. Driver issue? Do I need to start the F@H client in a particular mode? Thanks!
P.S. no laughing at my old GPU!
Code:
09:13:04:WU01:FS01:Connecting to 65.254.110.245:8080
09:13:04:WU01:FS01:Assigned to work server 128.252.203.10
09:13:04:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:GF110 [GeForce GTX 580] from 128.252.203.10
09:13:04:WU01:FS01:Connecting to 128.252.203.10:8080
09:14:37:WU01:FS01:Downloading 86.23MiB
09:14:43:WU01:FS01:Download 13.34%
09:14:49:WU01:FS01:Download 30.37%
09:14:56:WU01:FS01:Download 44.94%
09:15:02:WU01:FS01:Download 57.11%
09:15:08:WU01:FS01:Download 71.90%
09:15:14:WU01:FS01:Download 87.26%
09:15:20:WU01:FS01:Download 96.54%
09:15:22:WU01:FS01:Download complete
09:15:22:WU01:FS01:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:11764 run:0 clone:3244 gen:22 core:0x22 unit:0x0000002780fccb0a5e6d85f1729f0e06
09:15:22:WU01:FS01:Starting
09:15:22:ERROR:WU01:FS01:Failed to start core: OpenCL device matching slot 1 not found, try setting 'opencl-index' manually
09:16:22:WU01:FS01:Starting
More info on my system:
Code:
*********************** Log Started 2020-03-31T08:44:54Z ***********************
08:44:54:************************* Folding@home Client *************************
08:44:54:      Website: https://foldingathome.org/
08:44:54:    Copyright: (c) 2009-2018 foldingathome.org
08:44:54:       Author: Joseph Coffland <[email protected]>
08:44:54:         Args: --open-web-control
08:44:54:       Config: C:\Users\***\AppData\Roaming\FAHClient\config.xml
08:44:54:******************************** Build ********************************
08:44:54:      Version: 7.5.1
08:44:54:         Date: May 11 2018
08:44:54:         Time: 13:06:32
08:44:54:   Repository: Git
08:44:54:     Revision: 4705bf53c635f88b8fe85af7675557e15d491ff0
08:44:54:       Branch: master
08:44:54:     Compiler: Visual C++ 2008
08:44:54:      Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
08:44:54:     Platform: win32 10
08:44:54:         Bits: 32
08:44:54:         Mode: Release
08:44:54:******************************* System ********************************
08:44:54:          CPU: AMD FX(tm)-4300 Quad-Core Processor
08:44:54:       CPU ID: AuthenticAMD Family 21 Model 2 Stepping 0
08:44:54:         CPUs: 4
08:44:54:       Memory: 7.98GiB
08:44:54:  Free Memory: 4.61GiB
08:44:54:      Threads: WINDOWS_THREADS
08:44:54:   OS Version: 6.2
08:44:54:  Has Battery: false
08:44:54:   On Battery: false
08:44:54:   UTC Offset: 1
08:44:54:          PID: 5848
08:44:54:          CWD: C:\Users\***\AppData\Roaming\FAHClient
08:44:54:           OS: Windows 10 Home
08:44:54:      OS Arch: AMD64
08:44:54:         GPUs: 1
08:44:54:        GPU 0: Bus:1 Slot:0 Func:0 NVIDIA:2 GF110 [GeForce GTX 580]
08:44:54:CUDA Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:2.0 Driver:9.1
08:44:54:       OpenCL: Not detected: Failed to open dynamic library 'OpenCL.dll': The
08:44:54:               specified module could not be found.
08:44:54:
08:44:54:Win32 Service: false
08:44:54:***********************************************************************
Folding still supported on the Fermi cards, but power usage will be high for ppd produced, likely under 50K ppd.
Looks like you are missing the openCL part of the driver. need to install driver from NVidia web site. probably best to use the newest NV driver that supports your card. W10 has tendency to remove/upgrade items that microsoft does not need for your windows experience. Use GPU-Z to make sure you have the openCL part of the driver and that it stays installed. If w10 removes the openCL, doing a driver rollback in the devices should reinstall the openCL, and hopefully keep it installed.
...Looks like you are missing the openCL part of the driver. need to install driver from NVidia web site. probably best to use the newest NV driver that supports your card...
Note to all: worked perfectly. Note to self: Drivers......
Thank you!
