- Mar 7, 2008
As mentioned in another thread, I just received 3x RX 580s. Primarily to get one steam achievement... am I crazy? Probably... anyway, simple enough plan. I previously checked my Asrock X99 Extreme3 board supports 3 way Crossfire, running 16/16/4 with a 40 lane CPU like the Xeon I have. Based on TDP, the three GPUs would be around 555W so the existing 550W in there isn't going to do. I'll just grab the old Corsair TX750 from another system... it's in the 1700/Vega system. Doh! So that's now shut down and offline until I back fill it.
The case I have didn't have a gap between the lowest PCIe slot and the PSU shroud. I thought I'd use a PCIe extension I bought for another project, but the system was unstable AF. I've noticed in the past, nvidia cards seem to work fine with it, but AMD cards really didn't like it. This was no exception. Ok, let's take the whole lot out of the case then...
And away we go! Without any tuning, I got 15386 in Fire Strike regular. I think the CPU might be holding it back... it's an E5 2683 v3 Xeon (ES), and although it has a ton of cores, the clock only goes up to 2.3 GHz. That run was enough to get me the achievement, so I'm done... or am I? I'll try to OC it later. I've submitted it to the bot, easy gold medals as no one else is running 3 way Crossfire it seems. 4x and 2x yes, but not 3x. Snag is PC is only Win7 so no Time Spy. Don't think I have a spare disk at moment for a temporary install...
