- Apr 16, 2001
Hi guys, I just scored a HP laptop that was designed for Windows XP. I want to run some older games on it. But I also do not want to overwrite the internal hard drive until I can verify that Windows 98SE will run on it.
So I set out to install Windows onto a USB drive. I get as far as the first Windows setup screen and it gives me an error that Windows needs at least 16 mb of memory to install. When I click on ok it takes me out of setup and back to DOS prompt.
The laptop is using Pentium M and has 2GB of RAM with 1gig internally installed and the other in the expansion slot. Going from 2 to 1 gig gives me the same result. I am not looking to source RAM (don't want to spend the money.)
Is there a modification I can do to the install files to only recognize 512mb of RAM? Or some other work around?
Thanks for the help guys.
