What has been your method of overclocking to this point? Were you using some auto overclocking genier in bios or some Windows software? Or were you manually manipulating individual settings in bios?
If you are using CPU-z to check system settings, realize that it will report the RAM speed at half of what you expect. The reason is that CPU-z is reporting the ram bus speed, not the DDRx transfer rate which is twice the bus frequency.
Also, it looks like your core voltage may be too low to overclock further. CPU-z shows it at 1.408. I would think you would need more than that to get a higher overclock but high core temps may also be limiting you. What CPU cooler are you using? We need more info about your system. Have you monitored the core temps with HWMonitor while stressing the system for say, 20 minutes with the Prime95 blend test? If not, download these two programs and check that please.
We would like more info about yours system. All we know is what CPU, motherboard, GPU and ram you have. It would also be good to know about your case make and model (and how many case fans you have) to get an idea of how good you ventilation is and also to know about your CPU cooler and your PSU make and model.
