Hi. Im fairly new to overclocking and i wanted to overclock my q9650.
I tried the settings at the below and got through to windows but after a few seconds later it crashed and gave a blue screen memory dump i belive...
I need help as i do not know what am i doing wrong exactly...
The specifications are as follows:
And the BIOS settings that i used:
Extreme Tweaker
Ai Overclock Tuner : Manual
OC From CPU Level Up : AUTO
CPU Ratio Control : Manual
- Ratio CMOS Setting : 9
FSB Frequency : 467
CPU Clock Skew : Delay 100ps
North Bridge Clock Skew : Delay 100ps
FSB Strap to North Bridge : 333
DRAM Frequency: DDR2-1121
Dram Clock Skew CH1 A1 : Normal
DRAM Clock Skew CH1 A2 : Normal
Dram Clock Skew CH1 B1 : Normal
Dram Clock Skew CH1 B2 : Normal
DRAM Timing Control: Manual
CAS# Latency : 5
RAS# to CAS# Delay : 5
RAS# Precharge : 5
RAS# ActivateTime : 15
RAS# to RAS# Delay : 3
Row Refresh Cycle Time : 55
Write Recovery Time : 6
Read to Precharge Time : 3
Read to Write Delay (S/D) : 8
Write to Read Delay (S) : 3
Write to Read Delay (D) : 5
Read to Read Delay (S) : 4
Read to Read Delay (D) : 6
Write to Write Delay (S) : 4
Write to Write Delay (D) : 6
Write to PRE Delay : 14
Read to PRE Delay : 5
PRE to PRE Delay : 1
ALL PRE to ACT Delay : 5
ALL PRE to REF Delay : 5
DRAM Static Read Control: Enabled
Dram Read Training : Disabled
MEM OC Charger : Enabled
Ai Clock Twister : Stronger
Transaction Booster : Manual
Common Performance Level [8]
Pull-In of CHA PH1 Disabled
Pull-In of CHA PH2 Disabled
Pull-In of CHA PH3 Disabled
Pull-In of CHA PH4 Disabled
Pull-In of CHA PH5 Disabled
Pull-In of CHB PH1 Disabled
Pull-In of CHB PH2 Disabled
Pull-In of CHB PH3 Disabled
Pull-In of CHB PH4 Disabled
Pull-In of CHB PH5 Disabled
PCIE Frequency : 103
CPU Voltage : 1.325
CPU PLL Voltage : 1.59275
FSBT : 1.37825
DRAM Voltage : 1.9
North Bridge Voltage : 1.4108
South Bridge Voltage 1.5 : 1.55300
South Bridge Voltage 1.1 : 1.20600
CPU GTL Reference 0 : Auto
CPU GTL Reference 1 : -45mv
CPU GTL Reference 2 : Auto
CPU GTL Reference 3 : -45mv
North Bridge GTL Reference : AUTO
DDR2 Channel A REF Voltage : AUTO
DDR2 Channel B REF Voltage : AUTO
North Bridge DDR Reference : AUTO
Load Line Calabration : Enabled
CPU Sread Spectrum : Disabled
PCIE Spread Spectrum : Disabled
Thanks for the help in advance
- ASUS Maximus II Formula P45 1600MHz DDR2 16x
- INTEL C2QUAD Q9650 3.00GHz 1333MHz 12MB 64BIT 775p
- SAPPHIRE ATI HD4870X2(256Bit)2GB DDR5 AVIVO 16X
- LG W2486L-PF 24" 2ms DVI HDMI (LED, 1920x1080)
- OCZ Reaper 2 GB 1066 MHz CL5 DDR2 Kit(2x1GB) x2
- Thermaltake Toughpower Qfan 750W
- Windows 7 Home Premium 64bit
Extreme Tweaker
FSB Frequency : 467
CAS# Latency : 5
RAS# Precharge : 5
CPU Voltage : 1.325
FSBT : 1.37825
DRAM Voltage : 1.9
