Im sorry about posting such a common problem but ive scavenged google for 3 days now, tried everything I read but zero success. My corsair hs1a microphone is not working on my windows 7 desktop. To be clear, the headphone part works great but the mic does not. The pc recognizes that there is a mic plugged in but its not registering anything at all even if I yell into the mic, it just plays loud static when I record my own voice or check "listen to this advice". Over the past few days ive reinstalled windows 7 four times, updated realtek audio drivers, updated bios, did many windows updates, changed any volume control related to the mic, gone into device manager and reinstalled etc. Does anyone have any ideas?
Also, I dont know if this is something I should be worried about but since im paranoid ill ask. So after updating bios everything seemed great, it went successful and my boottime seemed to be enhanced by significantly less loading screens. However after that iwent to try and reinstall windows 7 again but for like 5 times in a row the installation froze once I selected which drive to install on. I then booted I safe mode and tried and it seemed like it was working so I canceled and decided to try again in regular mode, and this time it went flawlessly. Since then everything has been pretty smooth and most updates have installed (STILL HAVING THE MIC PROBLEM THOUGH of course), should I still be worried that something with the bios could be wrong?
Thanks for the help!!
Brief System Specs:
Intel i7 3770k
Msi r7850 2g twin frozr
Asus p8z77-v pro
Corsair vengeance 8gb ram
Ocz vertex 3 120g ssd (this is for the OS)
Corsair 600t
Please tell me if you need any more info, any help is appreciated. I need to chat with my buddies for starcraft ii!!!
Also to clarify, the headset DOES work on other devices. I tried on my bootcamp on my macbook pro and the windows 7 picked up the mic AND my voice just fine so its definitely not a headset problem
Brief System Specs:
Intel i7 3770k
Asus p8z77-v pro
Corsair 600t
