linglingjr
- Aug 15, 2012
My hardware is:
AMD athlon iix3 3.3ghz (didn't unlock 4th core)
Sapphire 6850
Ocz 550w power supply
760gm gs3 as rock mobo
WD blue caviar 500gb hard drive
Kingston 4gb single stick of ddr3
I have done all the overclocking with the asrock program. I also have a giant after market cooler master CPU cooler. For a very long time i had my cpu at a stable oc from 3.3 to 3.5 with out incresing voltage. So like a complete ****** I decided to increase the voltage of my CPU 0.5v and increase the over clock to 3.75ghz. The second I hit apply nothing happened so a minute later I shut down, turned it back on and nothing came up on screen but the CPU cooler fans were LOUD. The mobo speaker beeped twice with a big gap in between and nothing ever happened. So then in an attempt to reset the BIOS I took out the cmos battery put it back in, nothing happened same two beeps. So I'm guessing I murdered my CPU? Thank you for any help and yes I know I'm an idiot.
Sapphire 6850
