i am installing the aforementioned heatsink on my evga 580 and the instructions are terrible however most of the installation has been iintuitive, however i have on major question. when removing the plate that holds the factory thermal pads in place i noticed there are 6 dabs of a thermal paste of something along the small modules on the left hand side (in the picture provided)
my question is, if you notice in the picture off to the left of the R125 chips the small modules had thermal pads over them in addition to the small dabs of thermal paste or whatever. am i supposed to replace those 6 dabs of whatever that is, and if so then what do is use? i have as5, shin-etsu and some gelid thermal paste i am guessing the cheap gelid is sufficient or am i supposed to use the g-1 thermal glue on those modules?
