I just got my new water cooling kit and i dont know if i need to wash the parts out? How do i do it? Do i need to do all the components or only the radiator? Reply asap please! I have distilled water!
Thank you good sir! One last question (instead of posting a new topic), how tightly should my compression fittings be on each component. Should i use a wrench?
I don't usually run boiling water because I'll be running a kill coil in the loop but if you do run, run it through the rads only and don't burn yourself in the process. The rest don't need to be but clean them all out of debris. If you take a white small bucket you should see stuff that was in there from the manufacturing process.
