Over the course of 12 years I have amassed around 1TB of home videos, tv shows that I recorded with a video capture card, and videos that I saved from youtube.
The problem is that over that amount of time video codecs have changed quite a bit and I think it would be best that I re-encode everything to 264 so that it is compatible with my PS3 and so that I have the best size to quality ratio.
The problems/questions I have are as follows.
1) What program if any can automatically select an encoding profile by looking at the source files bit rate and resolution? I do not want to have to manually select the bit rate for each file I encode and I want to get the most out of the h264 and do not want to have to check each video to ensure the quality didn't get messed up.
2) What program will encode that fastest for multiple files. I have a NVIDIA GTX680 and a 6 core 960T running at 4GHz I would like to use a program that can take advantage of NVIDIAs processor and be capable of encoding more than 1 video at a time.
I have been looking at mediaespresso and mediacoder badaboom is not compatible with 600 series cards.
I would say the most important thing to me is that the program be able to automatically select the best settings for the specific file. I do not want it to use a much higher quality than needed.
The second most important thing to me is speed I need it to be able to encode from a list and if possible encode multiple videos at once.
