You don't need much above 1.21V. These cards should make 1300MHz+ on that voltage and real voltage will be probably higher than 1.21 anyway. You need modded BIOS mainly for higher power limit.
In theory 1.21V + LLC mod = 1.25V but on some cards LLC isn't working.
These cards are not scalling good above 1.3V on air/water and generally air/water gives similar OC just water let you keep card on lower temps so it will live longer.
I've used that hack, its simple and works.
Oh I've wanted to a few times but damn that Asus with their fancy power chips!!
