Hello Everyone!!!!
So few months I'm searching information on water-cooling, this is my time I decided I will did it this year. You can see below my configuration I would like to buy.
Intel Core i7-6700K (4.0 GHz)+ ASUS TURBO-GTX970-OC-4GD5 - GeForce GTX 970 4 Go+ ASUS Z170 PRO Gaming. I saw some video with the Tower "Fractal Design Define S Window Noir", seems to be a good tower for water-cooling with a lot of space and also that tower costs 100 euros. I prefer spend more money on my water-cooling than spend 250 in a tower.
You can see below a list of possible pieces of my water-cooling:
Pump: EK-XRES 140 Revo D5 PWM
Waterblock: EK-Supremacy EVO
GPU: EK-Thermosphere
Radiators: 2*Alphacool - Radiator NexXxoS UT60 Full Cuivre 360
Fitting?? Bitspower & EK???
Fans???
Rigid tube or Flexible ? Any difference about the performance?
I would like to do it this water-cooling with rigid tube, apparently it's very difficult for the first time, What do you think?
I saw 2 videos that's inspired me
My budget for this water-cooling is more or less 500 euros.
Why I want a water-cooling , Because I want silence and OC my system.
One thing that scared me is the maintenance, I saw normally I should change and clean the system every year? It's something complicated? How I can build my system in order to simplify this operation?
THanks a lot for your HELP
Fans???
