- May 13, 2003
- Just Behind You
guyz.... i have a bit of problem with some of my boards.. i.e
after 26 april 2 of my pc's are not working now.. even not showing the bios or boot screen on startup but blinking lights of cpu.. how to make them working.. i have tried every new hardware on these boards but of no fruite... how will be the problem solved..
and i want to upgrade bios of two motherboards in my collection. now when i downloaded the new bios for them.. and read there manual for bios upgrade guideline.. they said that i will need a bios flash utility for booting from floppy.. is it the only way to upgrade the bios.. if so then will same flash utility work for 2 different motherboards.. if yes or no then from where i will find flash utility. because i haven't found any flash utility on the websites from where i downloaded bios..i want bios flash utility for following 2 mainboards..
A Open: AX6BC
Mercury: KOB 630e CFSFX
any help will be appriciated alot..
thanking you..
Awi Ahmad
A Open: AX6BC
thanking you..
Awi Ahmad
