- Oct 21, 2015
- Portugal , Setúbal.
- Thread Starter
- #21
Pulsa: From your PM to me, just ask here instead.
I have no idea about the anti-freeze you have. Back in the old days late 1990's and early 2000's folks talked about Volkswagen antifreeze and I think Toyota as good stuff. One was blue, one was red. They said it was the best ones to use. Otherwise I don't have a clue, never used that stuff.
No luck on the pump top? Didn't think you would have any luck. Best bet is to return the pump, save and buy a better pump and use distilled water. You don't have to watercool right away right?
What about a DDC 3.2/3.25? A Swiftech pump MCP 35x/50x? A D5 basic? A D5 Vario?
dont think he will acept returns if nothings wrong whit the product when it arrives, when the pump arrives i will try to figure if i can get a non aluminium for it .
if not i will just use the antifreeze i have that haves anti metal / alloy inibitors including Aluminium + silver coil .
Dont need it right away cause i still need to figure where i will place everything inside de case , and set a suport for the rad outside the case.
