- Sep 6, 2009
Firstly I think I should introduce myself as this is my first post however keeping it short as I should stay on topic and not wander so I will state the topic first and introduce myself at the end.
Overclocking intel Core2 Duo E7500 ([email protected]) to ~4ghz
(ps do strong tags work in this forum rather than the ?)
My system is: STABLE AT CURRENT SETTINGS
CPU: E7500 @ 3.74ghz, 340mhz fsb and 11x multiplier (voltage sits at 1.37-1.38 default, temp 52degrees C in OCCT 34degrees C in idle)
Motherboard: Asus P5QL-E, P43, 1600*/1333/1066/800 MHz *Overclock speed, DDR2 1066/800/667
Ram: Corsair XMS2 800mhz 2gig single stick(have a choice of 2x1gig VS at 667 but figured I would buy another XMS in the coming weeks.)
Cooling: Old Zalman giganto copper CNPS, thermal paste applied thinly and properly. (1600rpm, blowing out side helped by extraction fan over the top)
Case: Thermaltake soprano 1st ed, 5 years old and needing an upgrade but still good airflow.
PSU: Thermaltake aftermarket 430w psu, rated for max 500. (this was bought BEFORE they had budget 430 and was a midrange, has lots of 12v railing free to my knowledge but I can post the specs if you wish, have a spare 500w psu but it isn't trusted)
Other less important details, XFX4850 OC'ed (single sixpin) 2x500gig WD, 1x1tb WD, 2xDVD 1ide 1 sata (gotta use that ide port for something).
Now onto the fun things folks. I KNOW this cpu is capable of much more, I know I am using air-cooling but I am sure I can push it further and I have tried lowering the mult and upping the fsb to maintain a stable OC at higher levels but failed miserably (-cough- bios clear -cough-) but I was doing a stupid suicide run I knew would fail.
I have been doing ALOT of googling and general research on this and have come up with other's results but no play by play per say. (other than one person who upped his vc to 1.7 ... I like my cpu to last a LITTLE longer... yes he was on air also and getting temps over 60 IDLE)
I digress, anyone who can give me a few ideas would be VERY much appriciated.
ATM the machine can run Crysis at 1980x1200 no AA all on VH at an easily playable 28fps average but what I want the extra CPU for is that extra bit of power for encoding and SupCom and sheer overclocking *****dness of myself.
As for myself I am a graphic and web designer out of college now and hating freelance work(money is good I just hate clients and working from home), I have been light overclocking things for 5 years now starting with my old P4 3ghz which I took to 3.8 on an old ABIT A8XE - 3rd Eye mobo... where has thou gone ABIT of yonder.
I am quite the bibliophile and audiophile and split my interests in a 4:4:2 with computing respectively.
I hope to be frequenting this forum more and more as I constantly get new tech to play with and will be having fun with some REALLY strange setups over the next 6months.
Also gotta say... damn uploaded an avatar only to read that I can't use one for another 49 posts XD
