Put it on BEFORE BED and LET IT CURE WHILE YOU SLEEP meant overnight to me. Wasnt talking, and didnt quote you though.
Anyhoo, glad the OP picked his paste out.
After applying the paste do you have to wait a while before booting up your PC?I applied some and booted up straight away and the monitor wouldn't come on[went into power saving mode]but after removing the paste it worked as normal,cheers
*** takes like 200 hours or some sbyte to cure. Not overnight.
Mx2,3 or pk1 and don't make it harder than it needs to be.
Remember the context. We are talking about thermal paste on a heatsink, not Preperation H.I still dont get it .
You want everyone to cure their bottoms? How? and how 'put it on BEFORE BED'?
Cure time on AS5 is a difference of 1-2C really. A questionable mount will wipe that difference out.
EDIT: Maybe the autocorrect got you? ***= AS5.
I've been playing around with noctua NT-H1 lately, since its has no break in time. Between that and the Arctic silver Ceramique'. Though I have a few tubes of Arctic Silver Ceramique' 2 that I have yet to test. Mostly the Ceramique' is for Cold benching, do to temp range and low cost.
I have found that for Ceramique' if you want to break it in fast and really make sure that you have a good interface between it and the pot/heatsink. You should apply it hot, take a hair dryer and warm both the tube and the surface you are putting it on. Then put the two together, after they are together heat the heatsink/pot again. (Use a temp probe to monitor the temp of the bottom of the heatsink or go off core temp if you have a board capable of showing this to you while its not on). Get the heat up to around 50-60c then let it cool from ambient temps (don't use a fan on it). Repeat this a couple times and it should be pretty close to the break in point if not already there.
