- Nov 28, 2001
- in a magical field
- Thread Starter
- #21
Thanks for the input, that's good to hear about the pump. Maybe in the open it's loud but it will be inside the sound-deadening P180 anyway, and mounted on some of Petra's Gel stuff with bolts isolated by grommets. Shouldn't be too loud then I hope
I was not really considering push-pull, just one or the other so seeing as there's no difference it will let me test both airflow layouts. A difference of 1.5C doesn't make going push-pull seem worth it to me.
I think I'll be good for mobo cooling too. I did make a thread in the Intel mobo section though outlining my reservations after remounting the heatsink assembly though; shouldn't have done maybe I'll get some thermal adhesive heh, or get some nylon bolts for hardmounting instead of relying on the weak springs...ah well.
