Hi,
I have a little problem that I can't figure out, so I'm here for help...
I have overclocked my memory to 3866 and it's stable.
I have (TWO) Memory Presets in Dram timing Control
1. 1.40v 4000Mhz 4x8GB Single-S B-Die
AND
2. 1.85v 4000Mhz 4x8GB Single-S B-Die
The first preload (1.40V) works, but when I load up the second preload it doesn't work. Why? What can I do to make it work? The timings are almost cut in half...
If you need to know what ram I have, it's the Corsair Dominator 8GB X 4 - 3866MHZ (CMD32GX4M4B3866C18)
AND
