Hi everyone. I have an old Compaq Presario sr1765an (I think the 'an' denotes ,Australian 240 volts model) with an AMD Athlon 64(V) 3400+ 2.2 GHz CPU on an MSI MS-7184 motherboard. I have added 4GB of RAM (only 3.25 GB usable) and a 1 TB SATA hard drive and installed Windows 7 Home
(32-bit).
Looking at the forum thread:-
http://www.overclockers.com/forums/showthread.php/670952-Help-me-upgrade-this-old-AMD-machine
it seems that the Athlon 64 X2 Dual-Core 4200+ Processor has the same requirements as my Athlon 64 3400+ Processor.
That is-:-
Athlon 64 3400+ Processor (2.2-GHz, 512K L2 cache, 2000-MHz FSB)
versus
Athlon 64 X2 Dual-Core 4200+ Processor (2.2-GHz, 2x512K L2 cache, 2000-MHz FSB)
Is this a simple chip swap upgrade and would I see any real improvement if I made the switch? Can anyone recommend a better simple solution?
Thanks folks.
(32-bit).
That is-:-
versus
Thanks folks.
