- May 8, 2012
- Argentina
I want to OC the base clock without having to disable Turbo but instead also modify the Turbo States, thing I can not do in the UEFI.
If I disable Turbo and set manually the multiplier to 20 and the voltage to 1.3v (everything else is default/auto) while in Windows the CPU does not idle properly; clocks stay at 4.0Ghz most of the while idle but the voltage never drops down to the idle value. I tried enabling HPC (disabled by default) and makes no difference.
This issue goes away if I leave the voltage to auto or manually changed it with Turbo enabled.
I want to retain as much power/energy efficiency as much as it is possible, I prefer not doing the "disable all energy features" approach.
I would like to know if there is a way to control the States of Turbo (clocks and voltages), specially since the default max turbo of 4.0Ghz @ 1.425v is too way higher then needed. I tried AMD Overdrive but that program is rubbish IMO.
HWiNFO:
HWiNFO:
