I love playing with these chips, they are the best chips to learn the ropes on as its all reference clocking and almost everything needs changing as you go, i think you will be limited by your'e board and cooler, as the proc will most likely do more but as trents said "top draw cooling" is needed to tame the heat. If you just want to see how far it will go then clock it back for daily running,take the case sides off or even better take it out the case all together (sorry! its a benching thing lol) and see how you're temps are after that! But as it stands 62 is too high for your'e temps and not being able to lower your'e your'e vcore is not helping you,although your'e not far of what it would need to run those clocks anyway.
