- Mar 15, 2008
So, I've been reading a ton of the threads around here (how did I never know about these forums before!?) and there is a lot of great advice for OCing, especially with the new Wolfdale cores (E8400 and Xeon E3110). I need some help with this process though since I've been out of the OCing game for about 4 years now (when I last built my own custom PC). Since I need to get the PC up and running ASAP when I get it (I use it for home and work), I'd like to minimize the amount of time I spend trying to figure out the order of operations when OCing etc.
Anyway, I'm building a new system w/ the following specs. It's already ordered and should arrive by Wednesday:
CPU: Xeon 3110 (virtually the same as E8400)
Mobo: EVGA NVIDIA nForce 780i
RAM: CORSAIR DOMINATOR 4GB(2 x 2GB) DDR2 SDRAM 1066
GPU: EVGA GeForce 9600GT 512MB (default @ 700mhz core)
PSU: ANTEC Quattro TPQ-1000
Case: ANTEC P182
(HDDs and other stuff are being brought over from my other PC until I have time to backup all my data and stuff).
Of course, no 2 components ever OC the same, so I'm not asking for any definitive figures for what I can expect to OC to... what I do want to know though, are some baseline numbers, and also a brief example of how to go about OCing this rig. IE: Change CPU core to X first, then increase voltage, then increase multiplier, then change ram timings, etc. Like I said, I've read a lot here and have a good working knowledge of a lot of individual stuff, but as a whole I want to be absolutely sure I do this one right.
Lastly, I haven't yet ordered an aftermarket CPU hs/fan... Is it feasible to do ANY overclocking with the stock HSF? If not, I was considering maybe the Cooler Master 92mm Hyper TX2. What's your thoughts? I know a lot of OCing won't be possible on stock, but for curiosity as well as the fact that I won't have the HS/Fan immediately, I'd like to know if I can get the ball rolling a little with stock.
THANKS!
Case: ANTEC P182
THANKS!
