buster bluth
- Jul 14, 2014
Hey folks my problem is near identical to this one - http://www.overclockers.com/forums/showthread.php?t=647607
I have tried numerous installs but always the same, ends up failing right at the end of finalization The message is "disk drive error. Please insert disk into disk drive. Hardisk1/" then reboots into an "cannot recover recovery.dat and a big red ERROR on screen". and virtually nothing works right from that point. Cannot load windows.
I try to follow the solution in the other thread but the options arent available in the asus laptops BIOS for ACPI XSDT Table or anything much else... so any ideas?
asus pro50n laptop that had vista until i tried to wipe it and install win7. I do have the asus disks that came with it. I formatted the vista partition (not the backup or data partition) from within the win7 setup menu, after the upgrade way failed also. Thanks for reading.
