Hi, new to this forum and to Ryzen systems.
I have an old Asus rig that is dying so I decided to upgrade rather than try finding an old MB. I bought an Asus x570-plus with a Ryzen 5 3600 and 16G of ram. I've researched setting up a usb install stick with the USB 3.0 drivers and this has not worked. I used a gigabyte link that is supposed to integrate the drivers and I've used the Asus EZ installer to do the same, but the install always hangs at the logo. I'm trying a procedure from a thread here{ https://www.overclockers.com/forums/showthread.php/781091-amd-ryzen-win7-iso-guide) and it mentions expanding the files from the install dvd. Not all the files are extractable so my question here is to use this procedure to I have to painstakingly copy the files/folders that are not compressed and then extract files into the correct folders using a tool like 7-zip? I have been searching on this all day and have not found a definitive answer. The dvd I have does not have a single iso file.
Tom
Tom
