Moved to your own thread...
Where are you at? What voltage? Cooling? Etc etc.... we need more info. Please list system specs (put it in your signature)
But my point is, you are doing better than most in your overclock already. Not every CPU made, even of the same make and model, has the same overclock potential. There are differences in the quality of t he silicon used form batch to batch when producing the same model CPU and subtle differences in the precision of the manufacturing process from factory to factory and from day to day. It may not be that the case that with a little more tweaking you will get up to the top spot. You may have gotten the max out of your CPU already.
Oh? Maybe sarcasm is tough to see through the written word. This has nothing to do with Americans.but americans dont get sarcasm
it was a sarcastic post but americans dont get sarcasm i understand i no i cant push it much further not without changing my cooling
You mean your first post? If so, I then take it to mean you were actually bragging about being "into the top 4", in an indirect way, that is. Americans do understand sarcasm but as ED indicated, subtleties like that don't always come across in print unless they are well-written so as to make the intention obvious.
A star used to mean you had posted enough times to have access to the Settings panel for your account and could then create a Sig. I don't think that is the case now. Not sure it means anything anymore. Sorry for the misunderstanding about the sarcasm. Since you were new to the forum we had no knowledge of your skills or experience. We get many who are noobs to building their own systems and to overclocking and don't understand that not all chips are created equal. Welcome to the forum!
