- Apr 6, 2011
Hello,I have P4 3,4Ghz Prescott E0 stepping processor, and I would like to clock him as much as possible to be stable, but I need your help.I managed to overclock him but not as I thougt it would be, I was hoping for 250FSB and memory to work on 500Mhz but computer crashed on loading win. need help with that, and I enabled PAT in bios but in win. he said that it is disabled and that happend when I move fsb from default 200 on up, dunno why.
My Pc conf.:
proc.: P4 3,4Ghz Prescott E0 in idle (firefox open,winamp,msn) he is 38-41C, in full load he is around 47 but not going further. I am talking temps in clocked mode in secound test.
Cooler: Scythe katana 3000 (max.speed no fan regulator)
MBO: Asus p4p800-e deluxe (mbo. has a drop on vcore when max. loading)
memory: 2x1gb ddr400 g.skill Dual Chan. working @ 2.65V 1:1 I put 400Mhz to work on becouse when I put auto he is working on 266 same happend when I put 250FSB and auto but he still wont start to win.
Graphic:HD3850 Sapphire 512Mb I put zalman vf900 (she is clocked two) Agp Pci Freq. on 66.66\33.33
hdd: Wd640Gb i seagate 160Gb
power supply: Seasonic 520W Modular
Case: CM 590 with two 120mm on front sucking air in,two on the top 120mm sucking air out and one in the back sucking air out.
Now I doing some combinations and testing
first test
Tried CPU @ 1.5V 240FSB memory ddr 400Mhz @ 2.65V after 38minutes Orthos fail.
second test
CPU @ 1.5V 236FSB memory ddr400Mhz @ 2.65V I cancel test after hour and ten minutes guess it's stable after hour I know I probably should left him like 3 hours of testing but I think if he was goin' to fail he will within an hour.This is not how I think It would be I was hoping like I said up there for 250fsb and maybe ddr500 if someone know some combination that I can do to achieve that please write,thanks.
I'am new here, I searched if similar thread already exists and I couldn't find it, so if it is, please admins/mods. move it, thanks.
My Pc conf.:
first test
second test
