- Dec 27, 2008
Okay, your temps look fine.
Chris, let's start over from scratch and do this systematically.
First, I want you to remove the 2 gb memory module and just go with the one four gig stick for now. This will eliminate this as a possible issue. You can put the other one back in later.
Then I want you to return every frequency and voltage setting to stock value, including the Processor Frequency Multiplier.
Then I want you to start increasing the "Processor Frequency Mulitiplier" by .5x increments. After each increment of increase, run a 20 minute Prime95 blend stress test to test for stability and temps. Have HWMonitor open on the desktop each time you test. If you pass the test, go back and raise the Multiplier by another .5x and retest. Repeat this until you cannot pass the Prime95 stress test. Then add .025 to the CPU voltage and retest. Let's see how far you get with this approach. When you get stuck, post back with pics.
