Hermes_tri
- Jan 9, 2013
I've got intel i5 ultrabook with two drives - 500 GB HDD and 32 GB SSD. All was working fine, until one day when laptop overheated and restarted itself. Then it got stuck on some file recovery string lines on start up and I made stupid decision to force restart rather then wait. After I have done that, Windows 8 had stopped loading at all and I was stuck on Medion logo. I could not even get to the Windows recovery options. I went into Bios and changed SATA connection from Raid to ACHI. Issue was seemingly fixe, and Windows was loading without problem. Ok, so this is where I am at now:
1. If BIOS is set to ACHI, everything is fine but SSD is shown as "Currently, this hardware device is not connected to the computer. (Code 45)" in the Device Manager and in Intel Rapid Storage it is shown as incompatible with status unknown.
2. If BIOS is set to RAID, Device manager is still showing the same, Intel Rapid Storage is showing it as working RAID 0 set for speeding up hibernation, etc. but after waking up the laptop from any king of sleep - BSOD comes up with DRIVER IRQL NOT LESS OR EQUAL with a reference to iaStora.sys which is Intel's rapid storage driver.
I have tried refreshing, recovering and fully reinstalling windows 8 but this issue is still present. I suspect that my SSD is DEAD, is there any way to check its status? I would also prefer to install Windows on SSD itself rather then using it to speed up hibernation?
Any advices on what to do, please!
