DirkDiggler87
- Jul 4, 2014
I'm trying to help a friend with a NEW build and I'm having an issue installing Windows 7. AMD FX-9370 processor with GIGABYTE GA-990FXA-UD3 motherboard.
When I "press any key" to boot from the cd/dvd it goes to the black screen with a gray bar at the bottom and loads the files, after that it goes to the next screen which is the Windows animation, a few seconds later the machine automatically reboots. Sometimes I get to see the blue screen that says "Setup is starting Windows" for a split second before it reboots.
This is a brand new, legit copy of 7 he purchased from NewEgg. But to be safe I did try booting from a USB flash drive with the exact same issue.
I am able to enter the Windows 7 setup in safe mode. The setup will run and install Windows 7 in safe mode but after the install reboots the machine I have the same issue with the constant reboot loop after the Windows animation is displayed.
Next I swapped out the Windows 7 DVD for my old Windows XP CD and I was able to install and run XP with no problems.
I assume that since XP runs fine its not a hardware issue?
I am stumped as to what the problem could be. Any help/suggestions will be much appreciate.
