Help!!! Should I buy Single or Double sided 400Mhz Memory for MSI K8N Neo2 Platinum?
Hello
Should I buy single or double sided PC3200 400Mhz Memory for MSI K8N Neo2 Platinum (Dual Channel 939 board)????
The MSI manual reports that If I put in 2X Double Sided memory modules in the board I can get Dual Channel at 400Mhz, but if I (later) put in 2 more Double sided 400Mhz sticks of Double sided ram the memory speed will drop back to 333Mhz.
The manual also says If I put in 4x 400Mhz single sided memory modules the memory will stay at Dual Channel at 400Mhz???
Q1) Can I get fast (2-2-2-5) Corsair or OCZ single sided memory in 512MB sticks (I think it is double sided by default)?
Q2) Why is single sided memory no problems with the MSI K8N Neo2 Platinum?
Q3) Do you have single or double sided memory modules?
I can honestly say that 1GB, 2x 512MB souble sided Corsair 2-2-2-5) will be all I need for now but if I still have the mainboard in 3 years and want to goto 2Gb I will be slowed down to 333mhz if I buy Double sided ram now.
help.....
Hello
help.....
