Should I run this on the new rig
http://www.sceptre.com/Products/LCD/Specifications/spec_x32BV-FullHD.htm
I found it for 599.99 which would be only a little more expensive than buying the tuner card for the other one.
http://www.costco.com/Browse/Product.aspx?Prodid=11236988&whse=BC&topnav=&browse=&lang=en-US
Paired with this
http://www.newegg.com/Product/Product.aspx?Item=N82E16815116007
I'm still in college, and it will also be the tv for my apartment, so running atsc/ntsc is a must. I guess i'm just looking for quality input on the sceptre brand, because I've heard good things about the Hans-G
Paired with this
