Hi everyone - hopefully someone's up late tonight and is willing to help
At stock speeds, everything is great. Board is fast, reboots fine, etc. Specs:
Asus P5Q Deluxe, Bios 1402 beta
Q9550, C1, w/ TRUE & 2xyate loon 120s
Corsair Dominator 2x2GB 1066
Corsair 750W PSU
4870, stock except for fan profile
2 x 640 WD HDDs
Temps are great - everything seems fine. Here are the OC specs:
JumperFree Configuration Settings:
AI Overclock tuner: Manual
CPU Ratio Setting: 8.5
FSB Strap to North Bridge: auto
FSB Frequency: 400
PCI-E Frequency: 100
DRAM Frequency: 1066
DRAM CLK Skew on Channel A1: AUTO
DRAM CLK Skew on Channel A2: AUTO
DRAM CLK Skew on Channel B1: AUTO
DRAM CLK Skew on Channel B2: AUTO
DRAM Timing Control: Manual
1st Information :
CAS# Latency: 5
DRAM RAS# to CAS# Delay: 5
DRAM RAS# Precharge: 5
DRAM RAS# Activate to Precharge: 15
RAS# to RAS# Delay : AUTO
Row Refresh Cycle Time: 55
Write Recovery Time: AUTO
Read to Precharge Time: AUTO
2nd Information :
READ to WRITE Delay (S/D): AUTO
Write to Read Delay (S): AUTO
WRITE to READ Delay (D): AUTO
READ to READ Delay (S): AUTO
READ to READ Delay (D): AUTO
WRITE to WRITE Delay (S): AUTO
WRITE to WRITE Delay (D): AUTO
3rd Information :
WRITE to PRE Delay: AUTO
READ to PRE Delay: AUTO
PRE to PRE Delay: AUTO
ALL PRE to ACT Delay: AUTO
ALL PRE to REF Delay: AUTO
DRAM Static Read Control: enabled
DRAM Read Training: auto
MEM. OC Charger: auto
AI Clock Twister: auto
AI Transaction Booster: manual, level 7, all pull-ins disabled
CPU Voltage: 1.25
CPU GTL Voltage Reference (0/2): AUTO
CPU GTL Voltage Reference (1/3): AUTO
CPU PLL Voltage: 1.52
FSB Termination Voltage: 1.12
DRAM Voltage: 1.94
NB Voltage: 1.24
NB GTL Reference: AUTO
SBridge Voltage: AUTO
PCIE SATA Voltage: AUTO
Load Line Calibration: Enabled
CPU Spread Spectrum: Disabled
PCIE Spread Spectrum: Disabled
CPU Clock Skew : Disabled
NB Clock Skew : Disabled
Cpu margin enhancement : OPTIMIZED
Advance CPU Settings
C1E Suppport: Disabled
Max CPUID Value Limit: Disabled
Intel® Virtualization Tech: Disabled
CPU TM Function: Disabled
Execute Disable Bit: Disabled
I think all of that is correct...
Anyways, it is orthos stable for 12+ hours, etc. and everything seems GREAT - until I reboot. When I reboot, it will not post (everything seems fine but I get no video on the screen). I have to reset the BIOS settings by power cycling and it will boot again.
Any ideas?
THANKS!!!
Corsair 750W PSU
2 x 640 WD HDDs
FSB Frequency: 400
1st Information :
CAS# Latency: 5
2nd Information :
3rd Information :
CPU Voltage: 1.25
DRAM Voltage: 1.94
NB Voltage: 1.24
Any ideas?
THANKS!!!
