Got everything together this weekend. Loaded it up with Windows 10 and updated everything with the MSI Live Update 6 program. Last time I ran MSI, they were on Live Update 4 and I could never get it to update things correctly. Live Update 6 worked great!
I decided to stop by the OC menu in the bios and was surprised at the amount of things I could change with the H110 board and a non-K processor. The multiplier was locked at a max of 3300mhz, but I could change it to run the 3300mhz all the time (normal boost clock). I didn't try any changes to bclk or fclk as I didn't see a need, but again there was the option to up those. Voltages were all available to adjust as well, and while I didn't mess around with them I might try to set a manual voltage to get the temps down a little. Ram booted just fine at 2400mhz, I decided to leave it there but had the option to again change it all.
In summary, this is my first time 'tinkering' with a non-overclocking cpu/board combo and I was surprised at the amount of flexibility offered still.
Loaded up the GoPro Suite program, uploaded an 8-minute GoPro clip, created a one minute long video with half a dozen transitions and exported it in the '1080p' setting as a trial. When I hit 'Export', I went up to grab something to drink thinking it would take a while. Came back and it was already done. The i5-6400 at 3300mhz and 16gb ram at 2400mhz seems to be a pretty good setup for handling video encoding.
My only complaints:
- Initially the CPU was randomly pegging 100% utilization on all cores every few minutes even with the PC sitting idle. It'd last about 15 seconds, but it was enough to make the fans all spin up (which got loud). After Live Update 6 got done updating everything, I haven't noticed this again.
- MSI has the smart fan profiles enabled from the factory, and they're set very high for the i5-6400. It let the CPU get up to 40C before it would bring the fan up to 20%, 50C was 35%, 60C was 50%, and 70C was 65%. If I'm reading correctly, the i5-6400 has a max temp of 71C so I adjusted the fan profiles to hopefully keep it safely below that. HWMonitor reported a max temp of 59C while running the GoPro Suite with the stock profiles. With my adjusted profiles, it only got to 52C (although with a little more fan noise now).
Overall, this setup works very well for what it was built for. It browses the internet, checks email, runs MS Office, and edits GoPro videos very quickly. Not bad for a grand total of $453! Pick up a RX 480 for $200 and this would be a decent gaming rig for $650.
