I'm in a bit of a bind here guys. My mother agreed to help me pay for an upgrade this year however, I feel she is getting cheated from the local computer shop. I was hoping you guys could throw some support in on my side as she is skeptical about me building it my self (even though I have installed basically every thing but a motherboard before). Any way... here are the spec of the two systems.
Computer shops configuration:
AMD 2800 computer system (I have no clue as to what components they are going to be using all they specified was 512 mb of DDR, an 80 gig hd, and the extras like floppy, dvd, modem, xp home, etc... and a 256mb video card, again I don’t know what card they will be using, as it doesn’t specify (I am assuming its some thing like a Radeon x800.
Any way, the total comes to $773.80
My configuration comes out like this...
Antec Tx105b (Includes 500 watt true power supply)
1gb of G.skill pc3200 (The extreme series
Hitachi t7k250 250gb SATA Hard drive
Sapphire x1800xl video card
Epox 9npa ultra motherboard
Amd athlon 64 3200+ (Venice)
Yes, I know my configuration comes out well over the $773.80, but I have been saving my money as well and managed to gather $260, so subtracting the 260 from my configuration, it actually comes out cheaper for her to go with mine. But again I restate, she thinks putting a computer together is rocket science. Also she is skeptical about buying from NewEgg. She also thinks taking the local computer shop's configuration, I will not see a drop in performance (this guy has her hooked on the idea 512mb of ram will perform well in to days games and applications).
So basically what I need you guys to do is convince her that building a system from scratch involves some risk, but it really is not that hard. Also I need you to persuade her that Newegg, or Zipzoomfly are reliable online vendors which can be trusted and lastly, that I will indeed notice quite a big performance drop if she were to go with the local computer stores configuration.
Thanks in advance guys
Lemings
Lemings
