- Jun 11, 2009
- Surrey, England
Well for performance to loudness? Say you had to have fans on 100% for a CPU say at 3.0GHz. For the same CPU with the H5O would you still need 100% on the fan(s) to keep it as cool?
Its price for performance, like I said. Those that cheer about it likely dont care about price to performance or havent seen a real w/c loop. And the failed logic (to me) in a concern over the weight of a heat sink with a back plate vs the possibility of a water leak or the pump taking a dump. Both issues are not exactly common, but come in to play with the use of a water system.
EDIT: If I was going to pay $80, Id rather have the Prolimatech Megalehems (or however its spelled) which cools MUCH better than even a push pull H50, please correct me if I am wrong.
Didnt we go over this in the thread you started on this Joe??
http://www.overclockers.com/forums/showthread.php?t=624285
(your white stars are gone? You change something?)
Its a small rad cooling a warm chip. Most will tell you in the custom world a minimum of 2x120 rad is needed for JUST the i7 920 at 4Ghz with HT. That is to get superior temps than that of an air cooler.Well for performance to loudness? Say you had to have fans on 100% for a CPU say at 3.0GHz. For the same CPU with the H5O would you still need 100% on the fan(s) to keep it as cool?
It is easy on the eyes... and seriously, to each their own (see my edit on that post)Yeah, I know.... lol... still looks good in some aspects...
naaa, it works, there is just better (air) for the money.Ah so basically it's purely for aesthetic purposes then. I was considering buying one =P Glad I'm not going to make the mistake now
+1 as usual to EarthDog =D
If you are going to go water, go custom.
