CmptrPrgmr
- Nov 13, 2013
I'm not a noob to building PC's, but with custom Liquid Cooling, I would say that I am.
My new PC that I'm going to be building is going to be really high end. I already almost have all the parts that I want chosen out. I will provide a list of them all.
Asus Rampage IV Extreme
i7 4930K (Being Liquid Cooled)
64GB Corsair Dominator GT 1866 (OC3 15000)
2x Asus Matrix 7970 3GB (Being Liquid Cooled)
Corsair AXi 1200 (Or just AX 1200)
2x Corsair Force Series GS 240GB (Boot Drive RAID 0)
2x WD Black Series 3TB 7200RPM 64MB (Raid 1 Storage)
Corsair Obsidian 900D
Those are the main parts. As you can see I am going to be using the 900D case, and this image below is what I kind of want the loop to look like. What I'm asking for is all what I need for it to be efficient and work like it's suppose to. I am going to be overclocking if you were wondering.
I just need some help on picking a good WaterBlock, Reservoir, Radiators and Pump.
Here is the image that I have created very quickly. It doesn't look very good at all, I know.
I don't know how big of a Radiator I can use on the bottom because I am going to be using a PSU down there (Kind of ob7vious, but just thought I would state that). I also need at least 2 drive cages being used, so I don't know where they could fit. Maybe they can fit behind the Radiator on the bottom. I do realize that there needs to be room for the Pump and Reservoir.
I also need help with the Loop, as I said that image is just something quick that I thought of. First it goes into the CPU, then into the 360mm Radiator to cool down, then into the 2 GPU's followed by entering the 480mm Radiator on the bottom.
I'm aware that there is Series and Parallel loops and I kind of understand them. It's similar to an electrical circuit I would guess. So if it was Series in the GPU section of the Loop, I wouldn't lose pressure?
What I really need help with is the Tubing and Fittings. I don't know where I should use Tubing or Crystal Link or what else there is. The Fittings are another thing that i'm going to need help with. I want it to look nice and professional as well as neat.
I know I'm asking a lot here, but I'm knew to this era of cooling per say. -/)
Another question that I have is that, is the Lamptron FC5v2 capable of running 8 of Corsair Air Series SP120 High Performance Edition on one channel? These fans run at 0.18A and the fan controller supports up to 30W per channel.
The way that I'm gong to connect each fan onto one channel is by Daisy Chaining(?) them together using lots of these 3 Pin Y Splitter Cables. I don't know if there is a better way to do, so if there is please elaborate on it.
I hope I covered everything that I needed to. If there is more I will probably ask away. But just to sum it up so you don't need to read through my Giant Novel again, here is what I need help with.
- Compatibility Check (I'm sure everything is compatible)
- Size of 480mm Radiator I can use on the bottom of the case
- What Radiators, Reservoirs, Pumps and WaterBlocks to use
- What Tubing I should use
- What Fittings I need
- Where I should use Crystal Link or what ever else there is
- If I can still fit 2 drive cages in the case
- How I should configure the loop
- What Coolant I should use
- If the Lamptron FC5v2 can handle 8 Corsair Air Series SP120 High Performance Edition fans on one channel
