- Aug 25, 2009
- Columbus Ohio
Hello, long time lurker, but this one has me stumped.
I got this board from New Egg along with G.Skill F2-8500CL5D-4GBPK and a Phenom II 720 BE. I usually test memory with MenTest even before installing the hard drive. I've upgraded to the newest bios F7 ( came with F5). The problem is that Mem Test fails with both sticks in dual channel at 1066. It passes at 800 speed dual channel. It passes single stick installed at 1066 ( both sticks independently). I have tried every possible combination recommended on GSkill,s site http://www.gskill.us/forum/showthread.php?t=1129 to no avail.
I have win xp pro sp3 installed just to see if it'll run ( which it does) but when I load some programs they won't run. No BSOD yet.
I tried Microsoft's memory test and 1 stick always fails the Stride 6 test and the other one always passes. The one that fails will pass 1 run of MemTest.
So, any help would be appreciated. Is it the memory ( which is on the approved list on Gigabyte's site), the memory controller on the processor , or the motherboard? Is it time to RMA the memory, get another of the same or is there one that will work better? Just want to get it running properly on 1066 ram before overclocking. If you need any other info, let me know.
Thanks, Dan
Thanks, Dan
