I have a chip here that I'm trying to squeeze for a bit more. I'm running into a bit of problems though. The board I'm using is a Gigabyte GA-970A-UD3 (Odd I know, but my previous board failed and was out of warranty).
I'm also running 8GB (4 2GB Dimms) of A-Data GS 1600mhz ram at 9-9-9-24 and 1.65V.
Ram divider is 1:4, I'm using the multiplier to overclock. This chip is gold as far as I can tell, able to do stock 3.2 at 1.175V and 3.8 at 1.41V. Getting to four requires too much voltage for my cooler to handle, but is possible (I can boot at 4 at the same voltage it will run at 3.8.
My main problem is getting a proper northbridge overclock and making the whole thing stable. I'm not sure how many volts to use considering the extra strain of the ram speed and amount. I'm shooting for 2400mhz (according to dolk's table) and would like a guidline. 2600 seems to require too many volts (I *think* i got it stable at like 1.275V, as in it will pass prime, but that brings up my other problem. This chip runs quite hot. I haven't found a cooler able to tame it as of yet. Prime temps at 3.8Ghz hit about 57-58C, and temps at 3.6 (at 1.33V) hit about 55. With that said, is there really a heat wall? I definitely noticed a speed increase between the two settings, and it didn't seem to impact stability. Especially considering it's not going to be running at those temps outside of the stress tests.
So basically, any help to tune this properly would be helpful. Should I drop ram speed? Disable CnQ? Etc
Also the stock CPU-NB voltage on this board is 1.105
