SOLVED Help
Jackrouach
Ok I dont play video games I received this build for a present I mostly download 4k mkv files 70-120gb files watch on 4k tv.
Case - phanteks evolv mini itx
Cooler - corsair 115i platnium rgb
Case fans - ml140 pro rgb
Mobo - asus astrix 390-i gaming
Ram - corsair vengeance pro rgb 2×16gb
CPU- i7-9700k
I have idle temps of around 34c-40c my house is around 23c.
I setup the fans as such in the
Front - intake 1 corsair 140m ml pro rgb and phanteks 140mm
Back - Ml140mm ml pro rgb as intake
Top - h115i with 2 Ml140 pro rgb pulling air from inside out thru the radiator.
I stressd tested 15min and temps went from 55c to 62c at most.
Is this normal should I be worried not sure??
I have him the aio pump in icue set to extreme and the fans on balanced.
The case fans set in corsair commander pro to balanced
We do not think about idle temps. Your work temps are around 62c. That's OK. Not fine, but OK.
As ehume said, idle temps are generally useless. The sensors in the processor are calibrated for the CPU shutdown temperature, and the reading is skewed the farther away the temperature is.
Your load temperatures look fine to me.
