- Jul 12, 2002
Greetings,
I'm running 5 phanteks rgb halos and 2 phanteks rgb strips in my case. I'm using the rgb header on my mobo with everything plugged in series.
The 2 strips show the correct colour codes but the halos don't and only for some colours.
For example, white on the halos looks a bit yellow/green and lavender/light purple looks more pink (not enough or no blue comes through).
Phanteks support said that the rgb header doesn't provide enough power for everything.
If this is the case, what controller should I look into getting or is there another workaround? The only product I know of is the Corsair Lightning Node Pro controller. I would just have to find it being sold separately without the 4 strips and additional accessories.
I use Corsair iCUE to sync all my components LED's.
Thanks.
Thanks.
