Well, it's basically as the title says, I have a friend with a decently old computer with a motherboard that is a GIGABYTE GA-G41MT-D3. I tried to help get new RAM, but I unfortunately think I made a terrible compatibility mistake and now I have friend that's basically out $25.
So I wanted to know if anybody knew the symptoms of incompatible RAM. The system wouldn't even boot up past POST and there was no beep codes. The RAM I got was a 4GB DDR3 PC3-10600 MT18JSF51272PZ-1G4D1BB.
It's 1333 MHz RAM and the motherboard only supports 1066, but I suspected that it would be knocked back down to 1066 like it should logically should.
I checked the table that GIGABYTE had up for supported RAM and saw that beginning note that they can't confirm every model\brand, and the list wasn't that big.
I'm looking for somebody to help confirm I made a mistake in my suggestion and suggest what might be the cheapest alternative. Well, any help would be greatly appreciated. Thank you.
