So I bought the Storm Scout 2, and 6 fans.
I was just wondering what would be the best configuration of fans?
the case comes with one exhaust in the back. It supports dual 120mm fans (optional) on the acrylic side panel window, two 120mm top fans (optional), two 120mm front fans or one 140mm front fan (optional), one 120mm bottom fan (optional), one 120mm HDD cage fan (optional) and one 120mm rear red LED fan (included).
Another thing is i was planning to use 2 fans on the hyper 212 evo in push pull. I was just wondering to put it in push-pull what way the airflow on each fan needs to be going.
will 3 pin fan plugs fit in 4 pin fan connectors and will 4 pin fan plugs fit in 3 pin connectors?
Last question is which way do the fans need to be pointing for a push pull on a 212 EVO do they need to go like --> ---> or ---> <----?
Thank you!
Thank you!
