- Jul 13, 2010
Let me begin with stating first off I had this problem on my old computer with the same watercooling but hoped a new CPU block and new system would solve the problem, alas it did not.
The problem is I am getting great GPU temps on my 8800 GTS but the CPU temps are horrid. The ambient in the house is roughly 70 degrees Fahrenheit. The cpu sits around 35 degrees Celsius idle but then ramps up to 50 to 52 degrees Celsius on load. The gpu almost never budgets from 47 degrees idle to 50 degrees load.
I know for a fact I have seated the Block correctly and applied the correct amount of Arctic Silver. I have done a similar setup on a friends computer and have build plenty of air cooled rigs over the years and always done this correctly and had amazing temps. I have also reapplied and reseated the block on this and the old rig I mentioned plenty of times to no avail.
Now the hardware.
Phenom X6 1055T @ 1.28vcore 3.5ghz
BFG 8800 GTS 640mb
These two are cooled by the following loop.
MCP655 Pump
Black Ice GTX 240 Rad/SilenX 80CFM Fans in Pull Configuration
ThermoChill 120.1 Rad/Coolermaster 90CFM Fan in Push configuration.
DD TDX CPU Block
DD 8800 GTS Full Cover Block (BFG Watercooled edition came with this)
XSPC Res
Kandalf Case
The loop is as follows Res---Pump---GPU---ThermoChill---CPU---Black Ice---Res
I tried every combination of the loop and nothing changed the temps.
The Black Ice is mounted in the front of my case with the air being expelled out. There are 90 CFM fans mounted on the floor of the case pushing tons of cold air up in front of the rad for it to grab so no worries as to it being fed hot case air.
The ThermoChill is mounted on the exhaust port of the case by the CPU pushing air out with again 90 CFM fans pushing air up from the bottom of the case to it as well as a 90 CFM fan pushing air fron the side fan hole on the side of the case right onto the CPU and in front of the rad fan.
Here are some pics I grabbed with the phone...sorry for the quality.
NOTE: THE PIX WHERE THERE IS NO SIDE FAN ARE OLD...THERE IS A FAN THERE NOW.
So the basic problem I am having here is the delta of the CPU temps.
I have seen people run air coolers and less extensive watercooling setups than mine and had much better CPU temps but if the answer is simply that my loop is only going to give me these temps then so be it...just seeing if this is normal or not.
Sorry for the horribly long first post I apologize.
Now the hardware.
BFG 8800 GTS 640mb
MCP655 Pump
DD TDX CPU Block
XSPC Res
Kandalf Case
