Hi everyone,
I recently completed my loop with 4790k and a single 290x. The 290x temps are good (never over 55C after a long gaming session), good temps both on the cores and on the 2 VRMs (i can monitor both VRMs).
The 4790k, however, gets hot very fast- 65C while gaming, and that is a lot more than i expected.
I have one 360 radiator and one 240 radiator, an MCP655-B, an EK block on the GPU and an EK Supremacy HF block for the CPU.
Both CPU and GPU are at stock speeds, and the stock voltage for the CPU under load is 1.171V, which should be quite nice for this CPU.
When using Prime95 large FFTs it jumps to 70C, and with small FFTs it will go close to the 90s, very unimpressive.
Anyone have any suggestions? (i will be reseating the CPU block, but any other thoughts?)
Thanks
Thanks
