i was soo mad when i woke up this morning to see that this pos i've built can even sustain 2.4ghz speeds at 255fsb for 3 hours in p95 that i decided i would post all of my info for the pros..
ok i've been at this for 3 weeks, 3 different boards (abit,asus, now dfi ), 2 different cpus (pIIII and now x2 3800) and 3 types of ram. all i have to show for that stuff is a bunch of oc settings, none of which can sustatin p95 for more than 4 hours on both cores.....very sad...considering i feel i have some of the best equipment... I've gotten very nice OC's but nothing close to what i feel i should be getting or close to what other ppl are getting and obviously nothing stable.
btw; i do all of my oc'ing in the bios, should i be using something like A64 (just for speed in testing, i know bios #'s are better)?
(attached are 3 screen shots from a64 tweaker, and cpu-z )
soooo..
ram= geil one s 2x 512mb (GOS1GB3200DC) (PC3200 DDR 400 CAS 1.5-2-2-5
CAS 2-2-2-5, PC4700 DDR 600 CAS 2.5-4-4-7) (http://www.newegg.com/Product/Product.asp?Item=N82E16820144341)
255fsb / 9.5 multi (i know it devides) / 1.525 * 110% vcore, 1.7v chipset / 2.8v ram / 480w cool max silent PSU (i measure the 12v at one of the connectors, always 12.25-12.05v with anything i throw at it)
heat is not an issue, except the system temp somes times goes to 60c... cpu always < 56c usually 53c load or less
Memory Timings:
CAS Latency (CL) 2.5T
RAS To CAS Delay (tRCD) 3T
RAS Precharge (tRP) 3T
RAS Active Time (tRAS) 5T
Row Cycle Time (tRC) 7T
Row Refresh Cycle Time (tRFC) 15T
Command Rate (CR) 1T
RAS To RAS Delay (tRRD) 2T
Write Recovery Time (tWR) 3T
Read To Write Delay (tRTW) 3T
Write To Read Delay (tWTR) 2T
Write CAS Latency (tWCL) 1T
Refresh Period (tREF) 200 MHz 15.6 us
DQS Skew Control Disabled
DRAM Drive Strength Normal
DRAM Data Drive Strength 1 (50% Reduction)
Max Async Latency 7 ns
Read Preamble Time 5.5 ns
Idle Cycle Limit 256
Dynamic Idle Cycle Counter Disabled
Read/Write Queue Bypass 16
Bypass Max 4
32-byte Granularity Disabled
some memory bench's from everest (im the a64 x2)
Memory Read
P4EE 3733 MHz nForce4-SLI-Intel Dual DDR2-667 7630 MB/s
P4EE 3733 MHz Dual DDR2-533 6920 MB/s
Athlon64 X2 2433 MHz nForce4 Dual PC3900 DDR 6465 MB/s
Memory Write
P4EE 3733 MHz nForce4-SLI-Intel Dual DDR2-667 2980 MB/s
Athlon64 3500+ nForce3-Ultra Dual PC3200 DDR 2600 MB/s
Athlon64 X2 2433 MHz Dual PC3900 DDR 2359 MB/s
Memory Latency
Athlon64 X2 2433 MHz Dual PC3900 DDR 2.5-3-3-5 42.1 ns
Athlon64 3500+ 2200 MHz Dual PC3200 DDR 2-2-2-5 45.6 ns
thanks guys! maybe this can be a good weekened after all
joe
soooo..
Memory Timings:
Bypass Max 4
Memory Read
Memory Write
Memory Latency
joe
