- Feb 18, 2002
I traced the problem of my HDs clicking at boot to my Antec TP380 power supply. My problems went away when I put in another PSU, so when I finally replaced the TruePower 380, I took a look at specs and noticed they are all identical except the PSU label (plus also old vs. new manual) shows the +12 V like so:
.........OLD....NEW
VOLT +12V +12V
TRUE330 17A 22A
TRUE380 18A 24A
TRUE430 20A 26A
TRUE480 22A 28A
TRUE550 24A 30A
Does that mean my new TP380 is like an old TP550?
(I know they released some new PSUs in new Sonatas, but shouldn't they have called them differently?)
Anyway, I looked at specs because I'd like to put an extra hard drive or two in and since I have no multimeters, can I find out through software or math what the consequences of prolonged use would be so I can avoid buying a new PSU which I didn't plan on doing just yet, especially if I'm really using an 'old' TruePower 550 Watt Antec that they now call TP380?
Full specs:
VOLTAGE +5V +12V +3.3V -5V -12V +5VSB
TRUE380 35A 24A 28A 0.5A 1.OA 2.0A
MIN. LOAD 0A 0.8A 0A 0A 0A 0A
REGULATION +3% +3% +3% +5% +5% +5%
RIPPLE & NOISE 50 120 50 50 120 50
(mV)
I would be adding Seagate 80GB Ultra ATA/100 7200 RPM (8MB) ST380013A
I may also be adding Maxtor 60GB Ultra ATA/133 7200 RPM (2MB)
to what I already have:
AMD Athlon XP 2400+ mobile 35 watt AXMD 2400 FJQ4C IQYHA 0402 SPMW
3 x 256 PNY PC2700 (Bravo chips) @ 6 3 3 2
[192] FSB x 12.5 = 2400 MHz @ 1.80 Vcore with memory frequency at 100% [192 FSB] @ 2.90 Vdimm
Epox 8RDA+ v1.1
Thermalright SLK-947U with variable speed 80x25mm Thermaltake Smart Fan 2
Antec SX-835II case ; 380W Antec TruePower TP380
Four 80x25mm Case Fans + 1 Variable speed 80x25mm Fan YS-Tech FD1281259B-2F
Western Digital 200GB Ultra ATA/100 7200 RPM SE (8MB)
Western Digital 120GB Ultra ATA/100 7200 RPM SE (8MB)
KHypermedia DVD+RW Drive 8X (rebadged BenQ DW800A)
Cendyne DVD-ROM Drive (rebadged Toshiba SD-M1612)
Sony Floppy drive
ATI All-In-Wonder 9600XT
Voyetra Turtle Beach Santa Cruz sound card
Silicon Image IDE Raid PCI Card SIL680RAID
D-Link Ethernet Card DFE-530TX+
Best Data 56K V.92 Modem56HP-92
ViewSonic 19” LCD VX910
Logitech Cordless Mouse & Keyboard with separate receivers
Visioneer USB Scanner OneTouch 9020
Lexmark Color Jetprinter Z45se
.........OLD....NEW
VOLT +12V +12V
TRUE330 17A 22A
TRUE380 18A 24A
TRUE430 20A 26A
TRUE480 22A 28A
TRUE550 24A 30A
Full specs:
(mV)
Epox 8RDA+ v1.1
Sony Floppy drive
