- Feb 18, 2002
Posted this at another forum because our forums were down, but I decided to post here now to let you all know.
I bought one of those USB drive sticks. I tried connecting it to the front USB ports and it didn't work. I then tried connecting it to the rear USB ports (the ones that are directly connected to my nForce2 mobo) and sure enough it worked.
I tried connecting some other devices to the front USB connector just to see, and they all worked (!)
What could be causing this USB stick to work on the mobo ports and not through the case USB ports connected to the mobo if all my other devices, including the USB card readers work on those same front case ports.
I have a dual Windows XP/Me system and the same behavior occurs on both.
My system:
AMD Athlon XP 2400+ mobile 35 watt AXMD 2400 FJQ4C
IQYHA 0402 SPMW
3 x 256MB Kingston PC2700 @ 6 3 3 2.5
[186] FSB x 13 = 2418 MHz @ 1.85 Vcore with memory frequency at 100% [186 FSB] @ 2.90 Vdimm
Epox 8RDA+ v1.1
Thermalright SLK-947U with variable speed 80x25mm Thermaltake Smart Fan 2
BFG GeForce4 Ti4200 8X 128MB; Antec SX-835II case ; 380W Antec TruePower TP380
Four 80x25mm Case Fans + 1 Variable speed 80x25mm Fan YS-Tech FD1281259B-2F
Well we can put all the assumptions to rest. It is Monday and I just spoke with Antec.
They confirmed this to be an issue with cases purchased last 2003 holiday season. The case USB ports are simply not 2.0 complaint + have issues with USB drive sticks.
As long as all your other devices work on these case USB ports EXCEPT for the new USB drive sticks only, it is a case USB port issue.
Spoke to someone named Francis at Antec. Very friendly, will send replacement. I've had major issues in the past with Antec but whoever said it was right: customers tend to be very impressed when they're met with friendly service.
All things being equal, it will be difficult not to choose Antec next time over another brand because they stand behind their products with friendly service and readiness to make things right!
My system:
IQYHA 0402 SPMW
Epox 8RDA+ v1.1
