- Oct 13, 2004
Holy CRAP!!
I'll quote what you need to read:
OP said:I just recently installed a new upgrade into my computer. An AMD Athlon 64 X2 3800+ was the CPU I chose. I've been fooling around and trying stuff out and it performs fantastically, but I have a bit of an issue. I'm part of a group for distributed.net, which is similar to the Folding@Home situation. CPUs run at 100% whenever they can to help achieve something. I was planning on overclocking my CPU to improve the number of keys I could crack in distributed, knowing that the 3800+ is well-known for overclockability, but decided to check my CPU temperature to see how much room I had. Sisoft SANDRA 2007 reports my CPU temperature to be at 113 degrees Celsius (254 Fahrenheit) when being under 100% load after a few hours. I saw this and I almost flipped! That seems incredibly high, and my comp should have blew up by now. I stopped distributed from running and after a few minutes checked again. My CPU temp was down to 65 idle. Right now it's at 50C idle.
This seems like it could really damage my computer. Last time I heard, your CPU shouldn't be over 50C period to ensure you don't shorten its lifespan. I'd appreciate some input here. I'd like to know how much damage I've already done and if I should consider getting extra cooling and maybe underclocking a bit.
OP said:Okay, I went into my BIOS and got this info from the PC Health area:
CPU Tcontrol: 65C
System Temperature: 61C
CPU Fan Speed: 0 RPM
System Fan Speed: 3020 RPM
CPU Vcore: 1.23V
VDIMM: 1.87V
The fan speeds reminded me of an issue I faced while assembling the parts. The CPU fan's power connector has 3 pin holes. The CPU fan power connector on the motherboard has 2 pins. I asked my more knowledgable friend over MSN about this and he said to look for an alternative for plugging the power connector into. I asked him if the "AUX power" connector on the motherboard, which had 3 pins like the CPU's, would be okay, and he said it would. So I took his word for it and plugged the CPU fan into the AUX power connector on the motherboard.
Therefore, the CPU fan is running at 3000 RPM right now. This seems low because when I was in my brother's computer's BIOS I remember his fan running at 4700 RPM. Maybe this is the reason my CPU is overheating?
Another Poster said:It sounds like your monitoring software is reading temps incorrectly...unless...you did use thermal paste, right?
OP said:I didn't use thermal paste/thermal grease...
OP said:All right. I'll make sure I get some ASAP. Thanks guys.
OP said:Found the problem:
Upon reading the manual, I noticed that it mentions thermal paste being already applied. I unmounted the heatsink, and checked for it. There was this thick solid plastic cover still attacked to the bottom of the heatsink! Apparently, I went a little too quickly while assembling the parts and didn't notice the plastic covering. This was the first time I've put together a new CPU and motherbaord in my computer myself (the alst time I did, I was 13 and had my dad assemble that), so I can use that as an exuse I guess . Either way, I was an idiot and in the future I'll go slower and check for plastic coverings on CPUs prior to putting them onto a motherboard.
I removed the plastic, it wasn't melted in any way (thank god), and now Sisoft SANDRA reports the idle temp to be 29 C down from 67 C. As for peak temp, 10 mins of full load has the CPU running at a cool 38 C down from the 113 C earlier. I have plenty of overclocking room now. ^_^ Though I do plan on buying a few fans and a high quality thermal paste in the future just for good measure.
p.s. To the guy who asked about cut-off temperatures in X2's, I noticed in my BIOS that the default cut out temperatures were disabled by default. To all people owning EliteGroup Sys (ECS) motherboards, I advise you check your BIOS's concerning the cut-off temps.
113c !!! THATS CRAZY!
If this really did occur, this shows you that the CPU's can handle heat for SHORT PERIODS OF TIME. It's not going to kill her! Long periods of time though is a different story.
It would actually be interesting if someone did a test where they made the CPU do full load at like 125c and see how long it took for the CPU to fail. (full orthos 24/7 til it died).
